captcharles
I've had to come home on one engine in my twin outboard. Will a Utopia 205 w/twin 4tec's run one one engine? Where I am it can a long time to get a tow.
Concerned in Washington
No. I didn't know anything about boats. It was my first time driving one. And I took it the distance. The only thing I thought of was reverse thrust. But it didn't help. But next day I guess it just removed itself. After the coast guard towed it cuz when I tied it down it came loose and THe coast guard found it floating in the water. Called me and charged me $8000 for towing it.
Hot water coming out of the drain plug could be from water that gets into the boat during use finding its way into the bilge where it sits close to the exhaust that warms it up.
The other place could be from an exhaust or other leak inside the engine bay.
Dry out the bilge before you take her out next. Before you leave the dock, check the bilge for water. If there's water, you have a leak and you'll need to fix it. If she's dry, then drive around and try to keep water from entering the boat. Stop periodically and check the bilge. If she's dry, then you more than likely are leak free, and you're probably getting water in the boat from normal use. If you do see water and you've ruled out splashes and such, then you'll need to track down the leak.
Places where you can have leaks:
hoses
through hull fittings
carbon seal
exhaust
Hope this helps
