OLD grey fuel lines
will95xp
Hey guys i have a 95 720 xp. I still have the old grey fuel lines and i would like to replace them before the summer. They dont seem to be causing any problems right now but i want to get it done before they do. Does anyone know what size and where i can get the replacement fuel lines. Thanks for reading and hope you can help me out.
Remember to use stainless steel clamps as replacements too. Replace each line one at a time so as not to forget which one goes where. I usually make a diagram of the hoses just incase you get pulled away in the middle of the replacement. Use "black fuel line" and maybe bring a small sample with you to get the exact size.
Karl
While replacing those lines, make sure you take your fuel valve off and clean it out or just replace it. The internal filter in your carb should be removed and cleaned or replaced. Good Luck
