timmyboy76
The Seadoo Rotax, If you install a blockoff plate, whether you continue to use the resivoir or bypass it, you still need oil for the crankcase...my question is,...seems that, everybody says to still use the injector oil for the casing, why, sice its not being injected anymore, cant you use some other type, thicker oil maybe?, since motor is turning 6k-8k rpm.
