Removed tank?.....!
If this oil tank was removed, look under the carb(s) and you should see a nipple coming out from the bottom of the block. This is the vent off the rotary chamber. It should have a hose on it. Trace that hose and see where it goes to. If it loops back around to the nipple on the opposite side, you need to disconnect it and hook it back up to an oil tank as soon as possible. At the very least, check the rotary shaft chamber for oil........:cheers:
