Today i changed the oil and filters in my 2007 speedster 200,i extracted approx 2.5 litres of oil from each engine , put in new filters and the 3 o rings filled the engines with 3 litres of oil each started 1 engine with no problem then started the 2nd engine and oil shot up into the air it came down on my head and all over the boat,oil is everywhere and i did not see where it came from i am thinking it came from the oil filter cap and shot into the air under pressure, the cap nut is tight but it is dark now and i cant see much.
If i pull the oil filter cap off will oil flood out every where? (dont want to pump out the new oil)
Does the cap go on a special way?
Has this happen to anyone?
Any advice on where to look firtst would be great.
