Hi, I have a 1997 GSX 800. It seems to have sat for a few years before I got it last year. I had some work done to it because it seemed that the carbs were dirty and it needed a backflow pressure regulator. I put it in the water this year (the work was done at the end of last year) and now it seems to run really well for some time, and then starts to get slighlty sluggish. It has to be held wide open to start and is definitely trying to foul the plugs. I have had it to the point where the plugs have to come out repeatedly and be dried and it has to be cranked A LOT for it to fire. Starting fluid does not even help it start, and I have been told it is not a good thing to use it anyways, but I was at a loss for what to do. When it finally starts a lot of oil/gas comes out the exhaust. From what I have read (I'm new to the forum and PWCs) I could have bad seals in the lower end of my motor and this is causing oil to leak in. After everything I've checked this seems to be the problem. I'm assuming gas also comes out because I have to crank it so much to get it to start. Does this sound like the seals need replacing and what does the replacement entail? I have a lot of experience with dirtbike/snowmobile motors and my dad is an auto mechanic so I think we could handle the task. Does the motor need to come out to do it? I would greatly appreciate some insight.
