oil recommendation
Petron
Guys, I just finished rebuilding my 96 GSX (787 Engine) topend, wanted your thoughts on the AMSOIL Interceptor 2 cycle oil.
This is the brand I've been recommended, I've not really heard any bad things about AMSOIL, except that its not available at the local stores.
What are your thoughts on oil?
Thanks
This is what is recommended by seadoo concerning gas and oil;
Use High quality low ASH API TC Injector oil.
Do Not use NMMA TC-W, TC-W2 or TC-W3 outboard motor oils or other ash less type 2 cycle oil. Avoid mixing different brands of API TC oil as resulting chemical reaction will cause severe engine damage. Never mix Mineral or synthetics oil together.
Never use fuel containing more than 10 % alcohol,( Methanol or Ethanol) as severe damage will occur. The minimum of 87 octane is recommended for most engines.
I hope this info clears this matter up.
Karl
