Well, it kinda depends on how the oil injection system was disabled. Look under the carbs. at the base of the intake manifold, is the oil pump still there? It will look something like this.
Lou
This is so true! I am 'pretty' sure, that the mech, as he told me, blocked it off but left the lines there and that the oil tank now just served to lube the bottom of the engine... and there is a line just sitting there blocked off somehow. dont remember how it is blocked off but i could easily find out when i go get her again. if i knew or had a visual idea of how, along with your picture Lou, HOW the pump is supposed to work and the purpose of those little hoses; looks like they... I think i see how it is supposed to work correct me and enlighten me if and where i am wrong:
using your picture as reference, and from what i remember seeing, i think there are a few tubes/lines coming from the oil reservoir/tank.
one of those main lines gravity feeds the crank wherever it goes into. another line, i think the one currently disconnected, connected to the silver inlet in the picture to the right and between the two little hoses. that line fed the injector valve/piston that, referring to post i read from snipe (
http://www.seadooforum.com/showthread.php?12708-Engine-failures-oil-injected-vs-Premix), controls the amount of oil being injected via a cable that is connected to the cam which is at the other end of the inlet port. Am I correct so far? If so, good. Where or what, is that cable connected to or where should it be coming from? I guess i can figure that one out if its there and refer to snipes post.
Is there a return line for the oil system? An oil flow, hose chart, would be very helpful to me i think. In snipes post, he mentions an oil filter that is not in your picture:
"Lines clogged?.....if you notice under the oil injection tank, there is a filter. This filter is of very fine mesh. There should be no way for any debris to pass through that filter. If someone's removed it, put it back on."
Not sure if i have one or not but will surely find out. If its there, can it be cleaned? If it is NOT there, where can i get one?
It seems to be a very simple mechanism that should, i hope, still work. Would having it being disconnected for some time; since the new engine was put in, damaged it at all? I know i am asking alot here, but i can do just about everything once i have the info, and a source i can trust which i do.
Whatever further help you can give me with this i truly appreciate. just that picture you provided was of great help! if there is a thread that would better serve me, please point me!
Thanks again...and as always... you guys are the BEST!
john
p.s. my boat is a 97 sportster with a 717 in case injector pump looks different than your pic
