Rich1983
Hey all, sent my cylinders away to get bored out 0.5mm and having new pistons to suit etc So while i'm waiting for them to come back thought it would be a good time to test my oil pump and replace some pipes etc
Firstly do the oil lines have to be a certain spec or will theres in the link below be ok to use? don't want to fit bad quality ones and end up having them melt or distort!
http://www.ebay.co.uk/itm/270820615227?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Secondly, Ive had the pump off and stuck the drill on it to test the flow and I get nothing. Stripped the pump and cleaned everything with nothing that looks worn/damaged and still nothing after opening the lever and spinning the shaft with a drill. And yes I did bleed the oil via the bleed screw.
Is there anything particular that stops these from working? Is there a way to fix them or am I better off sourcing a replacement?
