LikeabossTM
As you can see in the picture, the non-lever end loop of the return spring has sprung off of whatever it is supposed to be maintaining tension against. It's just hanging loose and doesn't return the lever to resting position. You can just see a bit of the end loop at the end of the red arrow.
I can't easily tell from my acrobatics where it's supposed to hook onto. Would that be the #18 bolt in the reference microfiche diagram, or somewhere else? Perhaps it loops around the nub of the pump body where the alignment mark is?
