johnhibbs
My oil pump/gear is working fine but I'm concerned it isn't not going to last for ever. When the plastic gear does break on the crankshaft the engine is going to self distruct. I can pre-mix the oil and gas but I would have to run a 50:1 mixture all the time. It only needs 100:1 during idle and it smokes enough as it is.
I found out that the Suzuki marine engines have an oil flow sensor on their engines. The part number is 16250-94710 and sells for around $20. I'm going to see if it's possible to use this sensor somehow on the output of the oil pump. It connects inline with the oil line. I will report back when I found out more. I don't know what type of signal the sensor generates but will find out.
