Hello all,
I was having trouble starting my 95 Xp. I put it on the trailer, and pulled it a little out of the water to check plugs .....
It cranked over, so I turned it off (to return to the water) . appx 1-2 oz of oil (it was darker than premix) came out of the exhaust pipe. The ski was tilted much more than usual on the boat ramp (tail done).
Once back in the water, everything worked fine, plenty of power all day long.
Does oil build up in the exhaust box?
Thoughts?
Peter
FYI: I replaced the wear ring without removing the impeller - What a difference in performance ! (it actually wasn't bad worn)
Thoughts?
Peter
