In addition to KustomKarl...
In addition to what Karl has said, you may want to look on the front of the engine where your oil pump is, check to see that the cable responds to opening and closing the throttle. If you had an engine rebuild, did they re-syncronize the oil injection pump to the carbs. The possibility of injecting to much oil will certainly foul plugs.
There is one other thing that may be of concern but for now, file it away in the back of your head. The rotary valve chamber is located between the two connecting rods of the crankshaft. This chamber is kept filled with oil from your oil tank. There is a seal on either side to keep the oil from leaking into the combustion sides of the pistons. If one or both of these seals are leaking, this will cause fouling. But too, if the engine had a fresh rebuild and the engine set for any period of time, the oil could have seeped slowly over time and you may just need to burn or blow it out.
I'd go with Karl's ideas, then turn to my post if you don't get safisfactory results. Karls touching base on all the probable causes from a sitting up condition and what happens to fuels and oils....lacquering, etc...
Good luck and let us know what you find out!.........:cheers:
