I have a 99 GSX LTD. After about 3 hrs of run time I noticed an oil trail running down the back cylinder. I start to investigate... It appears to be leaking from the black plastic cap with the red piece in it. I investigate further to find out that the back one is not assembled under the cover. I proceed to take the other one apart then put the back one together as the front one is. The next day I hit the water & notice my ski is running smoother on the low end but now has less top end. A few hours into it, it fouls out the back cylinder plug & I'm forced to putt home on only one cylinder. Any ideas as to whether or not these two situations could be connected?
Thanks in advance,
Landon.
Thanks in advance,
Landon.
