Working on a 2003 gtx supercharged 4 tec.
Just rebuilt the supercharger and took it to the lake. About two hours in low oil warning beep hit.
After inspection I can see oil dripping past seal on drive shaft next to supercharger. The hose clamp around the seal/hose 0n drive shaft near engine was lose and slid over. I assume I pushed it when messing with supercharger.
My question. If the clamp is loose will it leak oil under load or is the seal bad? There were no signs of oil before….not until the rebuild and re-install of supercharger.
Thanks!
Thanks!
