BigBoss97 New Member Jun 29, 2009 #1 i have a 1997 GTI and was wondering how much oil i should expect it to use or what type of ratio it runs on
JJinSC Well-Known Member Jun 30, 2009 #2 If the oil injectors are still working the mixture is variable. If you are running premix some say 40:1 some say 50:1. I believe 50:1 comes out to be 1 qt per 6 gallons of gas.
BigBoss97 New Member Jul 1, 2009 #3 i'm not running premix, and i thought it was variable, i just wasnt sure what the average mixture would be
slowboatn New Member Jul 1, 2009 #4 It depends where you set the oil injection pump. I'm not sure of the ratio though. I can find out.
BigBoss97 New Member Jul 7, 2009 #5 what do you mean where i have the oil injection pump set at? am i able to adjust it then?
