oil injection removal
Albysure
98 sportster 1800. Got the two bolts that hold the unit on but it is not free. I can pull and move it around just slightly. Is there another bolts or shaft internal that im missing.
Thanks Guys
I'm assuming that you are removing the oil pump. On a 717 you need to remove the carbs., remove the intake manifold and remove the nylon gear from the shaft of the oil pump.
Lou
