The boat was serviced by my local dealer, when the carbs were done. The plugs have spark, but new ones wouldn't hurt. If I put a little premix in the carbs it fires it 2-3 sessions of cranking, letting the starter cool the cranking again until it fires up. What gets me is that if I try to rev it when running, he hesitates and sputters. Could it be the high or low speed screws? Also, they did replace some type of diaphragm in the carbs. Both cylinders compression checked and on spec according to dealer. Also, the engine does not fill with oil when left for extended periods. Lastly, I have the 787 but am unsure of what power valves are. (Rave?)
Thanks for the help!
- Spark is good (new plugs might help marginally.)
- Brand new battery fully charged (no issue there)
- carbs serviced so they aren't clogged or dirty.
- Seems to start MUCH easier when warm. Abnormally so
- New fuel throughout, fuel filter checked and cleaned
Not sure if this is relevant but the overheat sensor is bad and needs replacement, could that be a part of it?
