Oil injection cable....help needed!
Jfrymania
Hey guys I'm removing the carb for cleaning. I got it off except for the oil injection cable on the bottom. I can not figure out how to get it off. The other two I just pulled he slack and twisted over pulling through the opening. Please help, thanks!
If I remember correctly, there are 2 nuts, one on each side of a bracket, holding the cable in place. The nut towards the pump needs to be unthreaded all the way, then the cable can be removed through the slot in the bracket. Hope I am explaining myself clearly. If not, someone else will chime in I'm sure.
Undo the retaining nut, pull on the cable so you can slide it off the bracket, then you can pull it off the wheel.
