oil injection 657
xtrema2
I would like to do away with the oil injection on my 94 gtx 657. I was wondering can i take the two little lines off my rotary valve cover or the intake,I cant really tell where they go, and just plumb them back to the oil tank. Would this let me go premix or is there more I would have to do?
premix
I dont know if I am right but there is 2 lines from the oil tank . the bottom goes to the crankcase the top to the oilpump. I cut the top line put bolts in each side and ziptied them in . I have read 40:1 or 50:1 16 oz per 6 gallon tank..
Block-off plate...
You can install a block-off plate, to entirely relieve the manifold of the oil pump, or you can cap the line that has the filter. Leave the little lines alone, if you go with capping the filter line...:cheers:, also, you'll still need to leave oil in the resivoir, because this oil also lubes the crankcase...
