2strokenewbie
Any tips on how to replace the oil seal between the magneto housing and engine in hull? I have oil in my magneto housing. I do not know if this is my only oil leak. I purchased the ski with a lot of oil residue in the hull. The ski seemed to be running fine until the trigger coil in the mag housing broke. Now that I have the mag cover off, I'm not sure if I should go through the trouble of removing the engine or if I should try to remove flywheel in hull and just replace the one oil seal.
