imnothot02
oil coming out of exhaust, both engines, on cold start, any ideas or is this normal...
To add with Nate here, after you start the motor, let it run for a couple minutes then shut down and read your plugs. If they are wet, the possibility of a cold burn is possible. You can also look at your gap or replace the plugs.
Start and run till the smoke or oil and gas seem to clear, then check again. This doesn't take away the fact that your rotary seals can be seeping by.
There have been persons, on this forum, with leaking rotary seals, who said their procedure was:
At beginning of riding day, pull spark plugs, crank it over, with a rag over to keep oil out of their face, and spew the oil out of the crankcase. Then, after doing this cleanout, replace the plugs, and run all day long!! (it would not turn over, or it would oil foul the plugs, on account of how much oil was in them, with the plugs in!)
Kinda funny. But if the seals are not leaking too badly...
Well, it just strikes me as odd that BOTH motors are doing the same thing, identically.
Just me thots.
Nate
