Eclipse1701d
Ok. So, I was working on the boat, and noticed some oil come out of the drain plug. Checked the dipsticks on both engines, and they are on the same place as last week. Where could it be coming from? I had both jet pumps removed and new seals and bearings, installed. Reverse brackets were rusted in place, so I replaced them as well. Shifter was tight, turned out to be the linkage in the back, which was also rebuilt. Boat is running great... Engines are synced. I am stumped. I realize that I should take it out, with the engines exposed, and have someone look for a leak or spray, but other than the oil filter cap, and the main seal, where should I look?
