You really should not be getting much oil via the oil pump unless the pump is operating (engine turning and gears ok to drive oil pump). Pictures in manual spell it out better than I probably can. When you speak of oil pump not operating, are you referring to the lever on the outside of the pump? The lever just meters how much oil mixes with the gas at the rotary valve (under carb) and the spring on the lever is designed so you will have max oil flow in case the cable falls off or breaks. Strizzo is on the money with the probable source of the oil.
I just went thru this on a 90 SP I just acquired that was sitting out for years, but have the luxury on the 580 engine to be able drain the oil out the bottom of the engine. If you get oil out of the pulse line and removed plugs you probably just need to crank it (short runs of 10-20 seconds so you do not burn up the starter ... let it cool while you charge the battery a little). I ended up flooding mine out, but when it started it belched, farted, and spit out a ton of oil and smoke. I found that I could not run for more than 20-30 seconds before the thru-hull fitting aft of the engine got hot to the touch and needed an hour or so to cool off enough to do another short run. After about 6-8 cycles of this it would fire up immediately.
If you do not have a service manual, download one; they are very good and explain how to test the oil pump as well as gobs of other stuff.
Good luck.
Rod
