1996 sea doo speedster 717 oil flow. Prior to replacing the oil and valve line and return oil line I discovered oil leaking a lot under the bottom of the starboard engine. I cleaned it up and replaced the oil lines valve and return. I install new oil (quicksilver PWC) after that noticed that starboard engine with the leak if not filling up I see large space with no oil at the valve line and also very little oil being returned.
It should be noted my oil clamps failed so I lost a lot of oil while replacing the valve line.
This is how the oil tanks was configured. Is that correct? I did not replace the oil filter on that line. Just need to make sure if the oil lines look ok to work properly.
Also, I need to understand the routing layout of the oil lines. Why are the lines attached to the T at the bottom of the hull will gravity be enough to push the oil back to rotary valve plug? Is it possible my oil tank is not working property to accomplish the oil flow?
Please advise.
See pictures of oil tank and valve line with space and return with almost no oil. The valve line picture is next to starter of the other engine. There is about 7 inch space with no oil. The return line has no oil to mention coming out.
Please advise.
