jkur10a
I've got an issue with my 1999 Challenger 1800. I bought the boat knowing that the crank seals on both motors were presumably bad (The price reflected that). However, I seem to be getting more oil than what I would expect and in a very short amount of time. Before I leave the lake, I pinch off the oil lines, both the RV line and the injection oil line. Still, after getting back from the lake and trying to start the motor the next day (lines still pinched, mind you) the Port motor will crank over fine a half dozen times or so (probably more) acting like it's going to start, then it will end up hydro-locking with oil. It's only the PTO cylinder and only the port motor. Both motors were hydro-locked with oil when I bought the boat, but the starboard motor hasn't taken on any oil since I purchased the boat a few weeks ago, including quite some time of it sitting without the lines being pinched.
Is there something I am missing, or is the crank seal just 'that' bad on my port motor and it needs a rebuild sooner than later? Maybe I'm missing a step or pinching the wrong oil lines? The boat has excellent compression and runs amazing on the water once I clear the oil out so that it will start. Any advice would be appreciated. There is a solid 1.5 months or more left of boating weather here in Ohio and I was hoping to make it through the season, but not sure I will be able to make it under these circumstances.
What do you all think?
