I changed my oil & filter last week on a 2003 Sportster 4 tec. I followed the guides on this site & everything went smoothly.
A few days ago, we put the boat in the water to go for an afternoon ride. After initial splash, I warmed up the motor for about 5 minutes, checked the oil level, & checked for leaks - all good.
About an hour later - my oil temp light & buzzer went off. I immediately shut the motor off, popped open the rear compartment & found the bilge full of oil. Checked the oil again & had no oil on the stick. I put 2 quarts of oil in the motor & started it back up to see what was happeneing. Apparently the top o ring on the oil filter cover got pinched & oil was spraying out while the motor was running.
The oil light didn't come on during this since I just put 2 quarts in it, but once the leak was discovered I shut the motor off immediately & got a tow back to the ramp, trailered the boat home, spent a few hours cleaning all the oil up & put the boat away for the night. I realize I need to go thru the motions of changing the oil again. But my main concern is if I caused any motor damage by what happened? What does everyone think?
