Hi Seadoo forum, I plan to do the bypass on my '00 Speedster this evening. I bought all the parts from boats.net however I want to know if its absolutely mandatory to do the "screw" on the engine block from the line coming from main tank (Qty 1 of 22-73379 Plug (crankcase pressure to main oil tank))? Or can I just leave it hooked up as-is? This will be easier to convert it back if I ever sell it. What am I risking by leaving this main line hooked up?
Also, how do you recommend I "prime" the engine with premix gas after I remove the oil pump? I don't want to engine to burn up from the few mins it take the premix fuel to work its way through the system...
Any feedback is much appreciated. Thanks! :thumbsup:
-Alex
-Alex
