Just want to confirm if I have a problem or not. There is a large air pocket on both the feed and return lines on the lines that feed the oil bath. About two inches long right at the nipples. Is this normal? It's happening on both engines. I have read that they are gravity fed and don't need to be bled. There is oil in the return line right up to the oil tank.
Another question: I snapped my oil pump bleed screw. I plugged the leak while I wait for a new pump. When I ran the engine (premix) the oil injection lines did fill up when I held the pump open, but they emptied again and now won't fill up, I assume I have an air leak where I plugged the bleed screw hole? The spring had disengaged, so I wound the pump to put tension on the spring and reinstalled the cable. Could I have damaged anything in the pump by turning it the wrong way? This engine was just rebuilt, and I don't want to take any chances. Thanks, Dan.
