OEM Wear Ring
smokinsvt
Where can i purchase the impeller wear ring for my 2002 Seadoo Challenger 2000? I found the wear ring assembly, but just want the wear ring by itself. Any help is appreciated.
If you are looking for a Merc wear ring, there is no "ring" by itself. The Merc unit is a one-piece cast aluminum part.
The separate "ring" is a mod. made by a machine shop. Maybe Impros?
If you are looking for a repair, most of us use epoxy and fiberglass or JB weld. About $20. Mine lasted 4 years.
Thanks Tim.
Is there a how-to on how to do the repair on the wear ring?
The wear ring "kit" that I found includes the essentials to put it into service. There is no removable "ring insert".
There are several how to's here for searching.
Basicly, clean the bore, paint with resin, lay in fiberglass. Sand, trim.
