Odd Squeak from Starboard Engine-almost like Jetson's car..!
tresvatos1
I seem to have the speedster up and running well after a usual de - winterization steps ( spark plugs, new oil, Rave Valve cleaning, etc. ). The thing I am running into now is that my Speedster's right ( starboard ) side engine has a squeek coming from it and almost sounds like the Jetson's car at low throttle. Also the throttle idle adjustment needs to be adjusted I imagine . because I have to give a little throttleto keep the starboard engine at idle.
I am just curious if anyone knows where this squeaking may be coming from,,?
Thanks
Sounds like it could be the typical seadoo jetpump rattle. Did you grease the driveshafts, that will usually quiet it down a bit. that along with the low idle will cause excess rattling.
Also, check your motor mounts to make sure there is not a loose one there, the right rear typically will loosen first.
Will check that tonight..! I did add grease to driveshaft recently though.
Thanks for the quick response!
Greg
