fireball451
Just got this ski a few weeks ago at a pretty good deal. Trying to get it ready for the spring. Not too much is known about it.
The know:
1997 SPX
Hull looks excellent except for some sun fading.
Very solid lookin ski.
No key.
Motor and inside was nasty, VERY NASTY.
Now I have a key.
I soaked down the motor with fogging oil.
Carburators are off and fuel lines have been replaced and the fuel system has been cleaned out.
Cleaned the inside and out and cleaned the motor.
Motor looks good on the outside.
Head has been off at some point.
Has a nice looking bright green gasket at the base of the jugs.
Was going to get a compression reading to see if she was worth trying to start.
Turned motor over a few times to blow out oil and whatever else had accumulated.
Hooked guage up and got:
1st run
Mag: 200
PTO: 165
Though these readings were crazy and tried it again the next day:
Mag: 185
PTO: 160
These still seem to be out there.
Alot of crap sprayed out of the pulse line (carbs still off) while the motor turned over.
It is bark brown, thin oil.
Same stuff that sprayed out of the cylinders.
What about these readings?
The know:
1997 SPX
No key.
Now I have a key.
1st run
Mag: 200
PTO: 165
Mag: 185
PTO: 160
