Nujet impeller 121-035-0701
artr
I have a jet pump for my 96 gtx that came with a Nujet impeller 121-035-0701. The impeller and wear ring are in good shape with about 0.4-0.5mm clearance. The pump holds pressure when I checked it. Anyone know anything about this impeller or have experience using it? I believe it is for a 96 gtx. I thought I saw where it was the same as a WSM SD A6.0. It does not have a groove where the drive shaft goes in for the drive shaft boot to lock into. I have an old oem drive shaft boot that I can shave the rib off of to make fit because I don't see those readily available.
