nothing at all
dothedoo
a 97 GTX and an 01 virage. Have had both on charger for most of the cold months and had both turned over last month, both batteris have charge but now i cannot get either one to turn over. the seadoo wont even make the beep noise when you plug in the laynard, and the guages work on the polaris but it will not crank either. im stuck, help
Check to ground conections, Sometimes the DESS lanyard magnet needs cleaned.
You might need to get a load test done on the batteries to see if they hava a bad cell or 2. They might have 12 volts but not enough amps to turn over the starters. Go to like Auto Zone for a free load test.
Karl
Who did your load test?
OReilly told me that they cannot load test the smaller batteries, only the big car batteries, which I think is BS.
