Mikey530
Hi! I bought a '95 Seadoo 657x GTX about 2 years ago. It was too good of a deal to pass up so I thought I'd try and fix it up! After a lot of no luck, i finally decided to completely rebuild the engine. Finished that up and it cranks great but wont pull gas to the carbs! We completely rebuilt them as well. I read a lot of different posts about why its not getting fuel to the carbs, and some saying that the carbs could the issue still, and one post specifically said try to hook a new hose up to the fuel in on the carb directly to a gas tank full of premixed. It tries turning over but at that point i was already low on battery. Hooked it up to the charger and put a few drops of premix in each cylinder and guess what? She fired right up and ran! I let it idle for about 10-12 seconds before shutting it off. So my question is what could be causing it to not be getting fuel from the actual tank? It has no grey tempo lines, and I took the fuel selector valve off and am able to blow air by mouth through it, so it dosent feel gummed up. Should I replace it anyways? Any other suggestions? Sorry in advance, im a complete noob when it comes to these types of things, just good at reading a manual lol
Thanks!
Michael
Thanks!
Michael
