slow cranking, 90 sp
ok im kinda new to all this jet ski stuff, so i'll get right down to it.
-1990 seadoo sp
-ran great when i picked it up
-wasnt aware that it had no drain plug
-put it out on the water, ran it great for about 15 mins
-brought it into shore, was gunna take a friend out
-tried starting it, was cranking really slow but nothing...lifted up the seat and there was water up about a quarter way up the hull
-got it out of the water and emptied the water out and started working on it this morning per directions from various threads on the forums
so heres the issues now. i got it to start ONCE with both plugs in. i didnt want to run it too long with no water so i hooked up the garden hose and bam nothing. started swapping plugs and drying them, and it will start with one plug in but slowly...with NO water. it cranks slow...i have a few batteries and none of them seem to be making it any better. as soon as i put both plugs in it cranks so so slow and will not fire up. what do you guys think? any help would be appreciated...thanks
kevin
-1990 seadoo sp
kevin
		 took it out, tested it and it spun great, nothing seemed worn out at all had plenty of torque...so i reattached it with all 3 bolts thinking that was the issue...still a slow crank with both plugs in...im so clueless as to whats going on...i can start the engine with 1 ONE PLUG in...either cylinder will fire and the engine will run but only 1 plug...as soon as i put both plugs in it has the worst time trying to turn over...i cleaned off every ground and hot wire i could...cut and redid terminals for the battery cables...still not starting with both plugs.  the battery ground is grounded to a stud on the top of the exhaust mani...that black curved pipe that comes from the yellow manifold and has 4 studs with nuts...would that cause an issue trying to start it?  im really out of ideas im so frustrated now
