jrcstudios
So I bought a Speedster. I've learned a few things, but not all. I've put aftermarket engine controllers on it, and fixed the horrible wiring associated with it. The engines run, but will die when at idle after running it hard, and not throttle up after getting it to start again. Someone with experience looked at it today and said the cooling system is rigged badly. I'd like some opinions on that, and what I need to do to make it right.
Is there supposed to be a restriction port here? it is open all the way through, same ID as hose.
the "leg" of the T goes to the water hose port. Most of the water just dumps out the back when running it off the hose. Putting a vise grip on that outlet is the only way water will come out of the exhaust.
Advice, please!! Thank you!!
John
John
