SportbikeRiderXX
98 Speedster:
When I attach the D.E.S.S. key, I don't get the Two-Beeps that should happen.
I know my beeper is good because the following all work as intended:
-One beep when placing it in neutral. -Four beeps when trying to start engine when NOT in neutral.
-Long beep when engine overheat switch is triggered (I tested this by grounding it while briefly starting the engine).
The only thing that does NOT work is the normal Two-Beeps when applying the key to the D.E.S.S. post.
And, if it's related, I am not able to get to the advanced diagnostics mode by pressing the Start/Stop button five times. (Then engines always crank even without the key on the post)
