hotrod6927
I have a 1997 Challenger 1800. Last weekend I brought it out tot he lake and the left engine seems to be running fine, however, when I give it throttle it is good to about 4000 rpms and then it shoots up to 6500-7000 rpms and then fluctuates back and forth from 4500 and 6000 rpms. It does allt his with out me changing the amount of throttle I am giving it.
Also while I am doing this the boat will not get on plane and it seems like it is not producing any usable power.
I am not sure what the cause of this could be. I have read some threads that indicate that imay be the RAVE. And I also have read that it might be a cavitation issue.
When the RAVE is properly functioing should water"leak" out from around the black cap? Because the effected engine's RAVE does not have any water "leaking" from it and the engine that is functioning does have water leaking from it when it it throttled up. Is this how it should work? Is there a way to test if your RAVE is working propperly?
Any advise is greatly apreciated. Also I am not very familiar with boat terminology so please spell it out.
Thanks in advance
Thanks in advance
