No thrust...
spanky
Took that seadoo on the river 2 days ago and it ran fine.
Then took it out today and it won't go I mean, when I give it full throttle it hits the rev limiter but does not go. It's wierd because it will go slow but not take off any idea's.
thanks.
hey...check the pump assy for any foreign objects, or a blasted wear ring, also check see if any hoses poped off...
pull the pump and put a nice fat bead of silicone where the wear ring hits the hull. use about a quarter of a tube. it is air leaking in at that point when trying to climb up on plane. unless of course when you have pump off you see real bad wear ring or impeller damage.
