No Start!
HighTrim
I have a 94 spi that won't start. Nothing at all, no click from solenoid. Battery new, fully charged. Tested start button, lanyard kill switch. No load being drawn from battery when start buTton pressed. Where do I go from here?
Cheers thanks!
Glad you solved the problem. you can follow the wire from the fuse to see where it goes.
ahha,,..i have a diagram.
The Y/R wire goes to the speed limiter and electronic control. The double B/W wires - 1 goes to the starter switch and the other goes to the speed Limiter/E. control (same as the Y/R wire)
The 3 red wires - 1 goes to the fuse in the MPEM, another goes to the battery, the single on the end goes to the starter.
