RiverLiver
2002 Utopia 205 240 EFI. Starter had been giving me occasional problems so decided to change it. When I went to start it up to pull it out of the lift it just cranked. Eventually I noticed the safety key broken and on the floor of the boat I never messed with it before so didn’t notice it missing) . Pushing the button in, it started up. I tried disconnecting the entire safety switch at the harness, thinking it might bypass it, and it started up, ran for about a minute, with throttle advanced, then died.
I hooked the safety switch back up and tried holding the button in and it would start but only for a few seconds. I knew my battery was going bad so replaced that with a new one but didn’t help.
Now it won’t start at all and just cranks. After more extensive digging, realized there is no spark to the plugs. If I take out the yellow/black wire from the bullet clip on top of the engine, there is spark.
I ordered a new safety key but looking for some ideas. Since the initial problem developed when the key broke, I have to think that has something to do with it but don’t know why it went from running a little bit to not starting at all. Does the ECU go into complete lock out mode and prevent spark at some point, no matter if the safety switch is pressed or not? I’ve been looking on the web and trying about everything I can think of. The three fuses in the harness on the side of the engine are good. Both fuel pumps are new the fuse is good. Any other hidden fuses?
Looking for some ideas before I go through the ordeal of taking it in. Thanks!
