Hello Friends,
I have a 2002 GTI (717 single carb). Over time I've replaced various parts including a full rebuild of the carb, gas lines, oil tank, bits here and there. I recently moved down to SWFL and took it out and rode around in the canals for over an hour at slow/minimal wake speeds. Ski did not really like this and would idle funny, sputter from time to time, and want to cut off. If I gave it gas it would wake up and be fine but had to dial it back as to not cause a fuss in the minimal wake zone. After the hour+ I went back to the boat ramp to grab a snack. I was about to head back out and go the other direction so I could get out of the slow zone but the ski would not start. I tried and tried. Choke no choke, nothing. Battery is new (2 months old). I packed it up on the trailer and headed home. Needing to do an engine flush, I went to crank it up and after a couple tries it fired up and ran (with a little throttle). It would shut off if I let go of the throttle, but it cranked up fine. What could be the issue here? The only know difference from other outings in the past is the long idle speed. Any suggestions on what I might be able to tweak/fix/adjust in order to avoid such a situation?
Appreciate any and all feedback,
GTA
GTA
