no speed?
allen c
while riding i hit a wake and the engine sounded like it would not rev up. i idledback to shore and loaded up. it ran fine when i flushed the drive . so we went back out. when i put it in the water it would not rev up again .after checking , the engine would rev to 3000 rpm but would not turn the prop.help???
The Impeller wouldn't turn at all? The seadoo is a direct drive. Did you snap the shaft to the impeller? at the back of the engine is a black boot with 2 clamps on it. Loosen the clamps and see it the shaft spins freely. It might just be the shaft is broke. If you look under the seadoo you could see the shaft from the bottom. Check to see it looks broken from that angle too.
Keep us posted on your progress.
Karl
