Traded a go cart for a 1993 Seadoo GTS. The seadoo was running till hitting a wave and died. I have no spark, have power going to coil when tested with a volt meter.[12volts]. it does pulse off an on. played around with the coil and got it to fire 1 time motor ran for about 30secs and died then no more fire.. Thinking its the coil that is bad any suggestions? Also having a hard time finding a used coil too try this out. I have to use the prosess of illimination since i don't have all the testing equipment.. Would really love to have some help here. before i spend a whole lot of money on something that won't fix it.. Thank You.. Also i checked the ohms on the coil from ground to where the wire plugs into it. i believe thats how you check it not sure but anyways had no change on the ohm meter stayed at 1 or better yet open circuit or what ever its called
