Hi, I am new to this forum and am not sure of all the rules but here goes.
I am having a problem with my 1992 GTS. The problem started as an intermittent one but now is pretty steady. I have no spark. The starter works fine and ocassionally the engine will fire after sitting a while.
I have checked
1. replaced the plugs
2. cut off 1/4" of the wire at spark plug cap end.
3.checked the kill & lanard switches for continuity
4.checked Secondary of coil (from between spark plug leads caps removed) and it seems ok (13k ohms).
5.checked MPEM with VOM- all readings within manual specs by +/- 3 ohms, infinite readings all ok
6.Checked resistance of stator generating coil thru red/black and black leads and got 60 ohms.
7.checked charging coil thru yellow & yellow & black leads & got.6 ohms
8. and last I disconnected the red/black lead from the MPEM to the coil and still had no fire.
Does this mean the coil primary side is bad?? is there a way to check this on a 1992 without a special seadoo meter??
I have checked
