My 1996 GTX will run great for a short time then bog down at WOT. Then it will start running ok for awhile, then bog down again (and again). When bogging down it reaches ~3500 max rpm. I noticed that the wire from the temperature sensor had come detached from the sensor at some point. Reattached it, cleaned the fuel filter, checked compression (ok), & checked fuses (ok). Seemed to run better for longer but then same thing occured. Bought a Clymers manul to see if it would help. Cleaned all wiring connectors (contact cleaner & dielectric grease), pulled out the CDI module & tested it per the specs. Have an open between the white/black wires (only one direction - negative lead to white wire; The other way seemed ok). Only issue is that the specs call for a black/grey wire which I don't have on that module. I may not have the correct CDI module or spec sheet.
Regarding the buzzer - At some point in the process I noticed that the buzzer will sound when expected - but barely audible (eg when plugging in the key). Took the buzzer to a boat shop who connected it to a car battery (go figure) and it worked. I had previously hooked it directly to my seadoo battery & it was barely audible. After it worked at the shop it worked fine when plugged in directly to my sea doo battery. Put it all back together in my craft & then it was barely audible again. Hooked it directly to my seadoo battery and again - barely audible. Not sure if more current than usual jarred it into working for awhile or if something else is causing it to not sound well. Hooked the leads up to the buzzer input, plugged in the "key", & only saw ~1.2V (~6V when hitting the starter switch 5 times). I'm not sure of the response time of my meter, though.
Any suggestions before I take it into a repair shop for both issues would be greatly appreciated. Not sure if the issues are related or not. I'd love to figure it out & fix it myself.
PS - not sure if it matters but last year the engine compartment flooded (long story but I don't plan on taking it back the repair shop that fixed a slow leak & caused a submersion...). Hence me trying to fix it myself.
Thanks!!!
Thanks!!!
