No power for my 2003 GTI LE
grifter
i had a new battery put in.but they got the wires crossed or something it blew the fuse on the pos.line i replaced the fuse all hooked up the way it should be but no power when i put the key on i get nothing.Check the other fuses and there good.is there a reset switch or something someone help me please.Thanks Doug
Fuses....
This sounds like a fuse problem. Are you sure you checked all the fuses, in both fuse boxes?........Your mpem is protected from just this kind of mistake by a fuse. So, this sounds like you've got a fuse that's blown.
i replaced the fuse on the line checked the fuses on the box in front by the charger and the fuse in back of the ski were the posative line goes am lost now again help.thanks Doug
