oldmanactingyoung
I got his used it sat for 2 years and it would not Crank so i poured fuel into the carbs and it Cranked on 1st turn and ran for 5 minutes  smoked heavily. I went out for the next hour and cranked it 3 times and it cranked 1st turn every time. on smoking issues i have had advice on it mine is now fuel issue.
Here is the problem. I let it sit for about 3 hours and went out to try it again and it cranked for about 2 seconds then died. I checked fuel filter a bit dirty but not bad. Cleaned filter and put it back on then turned dial to open or to allow fuel to flow and the filter filled about 1/3 full on its own. turned engine over with fuel line off of carb and no fuel comes out of line. Any help would be appreciated.
