Scott Rush
Let me start by saying this site has solved so many problems for me already!:cheers: Now i have a fuel problem as far as I can tell. I've done more work than riding so far this summer! I just rebuilt my top end because I had a rave break off in the cylinder and messed up my piston so finally I got it back together and when i tried to fire it up I had a fuel problem that I never had before. I blew air into a line from the back carb because there was no sign of fuel and it blew through the filter and tank and then fuel came flowing fine so i put the line back on and it ran fine on the hose so I went to the lake last weekend and it ran good, keep in mind I only putted around mostly trying to break it in.
Then after about an hour and a half I could feel it dying out not as much power and I let off the throttle and it died on me leaving me a long swim back with it.:rant: Ive put new plugs in and it still wont fire so tomorrow after I get off work I am going to replace all the gray hose with black and clean the on/reserve switch, but is there anything else? Should I have free flowing fuel at the carbs out of the lines when it is just sitting and not running?:stupid:
